Abgastemperaturfühler an das DataDisplay anschließen
- Fahrzeug: 328i
- Fahrzeugtyp: F30
Re: Abgastemperaturfühler an das DataDisplay anschließen
Dear Alex, I have installed the thermocouple inside my car and the car of my friend. I list here the problems:
1. my car, F30, N20, (AK01C version) I found the option to enable the exhaust gas sensor, but first I can't see difference in the temperature value showed respect to the option disabled (The F30 has an EGT value calculated) and second each time I restart the car I found the function disabled and I have to enable it again manually. I check the circuit wiring and it's ok. Since I have only one sensor I use only CS for bank 1, it's correct? Where can be the problem? I wrong something?
2. For my friend, E87, N47, (AK01E version) there isn't the option to enable the EGT in the features menu.
Hello,
thanks for your feedback.
1. It looks like i do not save the option correct. I will check this and fix it.
2. N47 was not planed for external exhaust temperature, i will also add it there
Hi dexter7385,
i try to finish the new update V4.106 and this is one of the last open points.
Just wondering for the N47 Enginge and external exhaust temperature sensor.
There is already a real sensor installed at the car because it is a Diesel.
So there is no need for an extra Sensor.
The other issue regarding the saving of the value for F-Series was my fault and is fixed.
- Fahrzeug: 328i
- Fahrzeugtyp: F30
Dear Alex,
Good news for my f30.
Regarding the n47 engine we don't have the original exhaust gas sensor because the exhaust mainfold was modified, and also because the temperatures goes out the range of the original sensor. So for us can be very important to read the external sensor, is one of the motivation of the choice of your data display. It can be implemented?
Thanks a lot
Thanks a lot
- Fahrzeug: 328i
- Fahrzeugtyp: F30
I see the new release, I will install as soon as possible in my f30 and give you feedback. Do you have enabled the external sensor also for the n47 engine?
Best
Alberto
Best
Alberto
Hi Alberto,
no for N47 it is not implemented yet.
But i will do it soon.
Too many changes in one version are not good, so i will now start releasing more versions with less changes that Bugs can be found faster and solved faster
Thanks,
Thanks,
- Fahrzeug: 328i
- Fahrzeugtyp: F30
Ok Alex, I'll wait for the next update.
Thanks very much for your work!
Alberto
Alberto
- Fahrzeug: 328i
- Fahrzeugtyp: F30
Dear Alex,
Are there any updates for the external exhaust gas temperature option for n47 engine? If you need help for testing a beta version I'm available. Let me know.
Alberto
Alberto
Hello Alberto,
please try this pre-release-version, i am not sure but i think i implemented it already:
http://link.ak-motion.com/V4109
Thanks,
Thanks,
- Fahrzeug: 328i
- Fahrzeugtyp: F30
Dear Alex,
I tried the pre-release, and I confirm you that it is not yet implemented.
If it's possible remember also to insert the exhaust temperature in the dashbar custom screen parameters selection, please.
Thanks
Alberto
Thanks
Alberto
