as stated in the manual, In order to carry out a diagnosis on the vehicle or to be able to connect a tester to the OBD2-Port, the DataDisplay must be disabled/locked. In this mode, if I understand correctly, some CAS informations are locked as anti-theft purpose. It's right? Since I want to update my DME with Esys, I find that with the display in normal mode the ECU is not reached (ok, it's normal), but if I lock the display DME is reached by Esys for reading, but I'm not able to flash the ECU resulting in some errors related to the VIN number. Are they related to some block functions of the display? If yes, can I enter in a sort of sleep mode with remote comand by PC in order to make flash without disconnect the display from the car?
I hope the question is clear and I don't make mistake in understanding how the lock functions work.
