hier nun ein Update auf die Version 3.07 für die E-Baureihe (F-Modelle dauert leider immernoch ein wenig)
CHANGELOG:
V3.07
- Implement E8X and E9X Diesel Engines (Ignition-Time replaced by Pressure before DPF)
- Add N20 TMAP Sensor Option (Workaround! Not real values - Factor 1.4 is used when read ECU Tables)
- Keep Display OFF after Switch-Off manually even Ignition ON/OFF change (Only Bootlogo will appear then OFF again)
- "Graphic-View"-Icon changed
- Torque Offset now allowed from 0.50 to 1.50 (as customer requested)
- Fix 0.00 Boost Text Output
- New Can-Bus Read Timeout (Freeze of some values)
- Add Laptimer (Up to 60 minutes) like a stopwatch with average speed and distance (not very precise for the moment)
- Add Temperature Setup for IAT (Like Water and Oil)
