Abgastemperaturfühler an das DataDisplay anschließen
dexter7385
Fahrzeug: 328i
Fahrzeugtyp: F30
Re: Abgastemperaturfühler an das DataDisplay anschließen
Beitrag von dexter7385 »
AK-Motion hat geschrieben: Di 23. Aug 2016, 17:24 Wichtig hierbei, es sollte ein Temperaturbereich von 1350°C abgedeckt sein, also z.B. -100°C bis 1250°C.
Hi Alex, it is very hard to find a thermocouple with those characteristics. Instead I found different models with range 0 - 1250°C. Are they suitable for the measure?
there are a lot "Type K" therocouples at the market.
But it realy needs to have this range, otherwise it will not measure exact.
They are very cheap :)
Example:
https://www.ebay.it/itm/1M-100mm-Spade- ... rk:10:pf:0
dexter7385
Fahrzeug: 328i
Fahrzeugtyp: F30
Thanks Alex,
yes, they are very cheap, but for this reason I have doubt on their quality (they are all chinese :? ), and I'm afraid it can create problems to my turbine if it melts and lost some pieces of metal :cry:
Anyway I'm searching some good quality brand. Thanks for the reply.
dexter7385
Fahrzeug: 328i
Fahrzeugtyp: F30
I want to install the exhaust thermocouple on an E87. The display unit is the AK01E V2 and not have the connections indicated in the first post. How I can connect the MAX 31855 to the display module? I see on one side 0V and 5V for the power supply but for the CS D0 and CLK signals?
Thanks you in advance for the informations. :mrgreen:
sorry for the late response.
I need to check the new PCB Layout of the AK01E V2 Controller.
It is not this screw clamp where you have to connect it, it needs to be soldered at the PCB itself.
I will update the Wiki the next days.
dexter7385
Fahrzeug: 328i
Fahrzeugtyp: F30
Hi Alex, do you have some news on wirings?
Sorry, i need to check a bit more.
It will be possible, one sensor is absolutely no problem but for the second one there needs to be another CS connection, i need to check which one is the best option.
I will connect 2 devices to one new Controller over the weekend.
Sorry for the delay.
dexter7385
Fahrzeug: 328i
Fahrzeugtyp: F30
I understand, in my case one sensor in enough! Let me know when you find the solution!
OK, so one Sensor is no Problem.
So here is a short description, i will put everything to the Wiki in a nice shape later.
MAX31855 ---> Controller
GND ---> 0V Screw clamp
VIN ---> 5V Screw clamp
DO ---> Solder to 35
CS ---> Solder to 43
CLK ---> Solder to 58
Does that help for now?
There is a small opening in the housing at the USB Side, where the wires can go out.
Thanks,
dexter7385
Fahrzeug: 328i
Fahrzeugtyp: F30
Thank you Alex, yes it is very helpful!
